And if you ever decide to redo your 175's transmission, the 200 has solid locating pins in the transmission.
I too had a cl200 that I bought for parts... I bought it of some yinzer that painted it teal, ugg. I cant think of any other 200 parts i used in my 175.
Re: "Patina" The 1973 CB175 Cafe Racer
Oh oh so you were thinking of bolting up the 200 to the 175 for more output? Wonder if I can run a smaller A-h battery then.
I am missing my kickstart bad (for troubleshooting purposes) so a re-do may be in my future...
you will probably want a new drain plug anyway so a carefully placed cold chisel will do the trick to break it loose or just weld a bar to it or a large cheap throw away 1/2 drive socket welded to it
in fact a socket welded to it could be a permenant solution
Def will want a new one. Now we-re talking. That's a great idea. I'll go the welding route. I'll probably let it soak in some Pb blaster too
Yeah I have that cl200 that I rebuilt with 1mm over pistons and decked for a bluprinted stock engine 208cc?. It just sits in the corner as of right now.
Now that i think of it, the main reason i bought it was for the cam, which I sent to megacycle and put in my 175. Since the 200 cam has bolt holes the 175 sprocket was machined to fit and slotted for adjust ability.
Really just a money sink. I had to buy another 200 cam and oil pump but I swapped the locating pins and stator from the 175.
It's got the oem 175 carbs bolted on but ive never fired it up
Yeah my 175 is around 182 now? What are you waiting on! Fire that thing up :)
Nah... The 175 is the one with the power! Short rod, cam, high compression pistons (198cc), lightened clutch, high perf valetrain and oversized valves!
Just to brag a bit.
acm177 said:
Nah... The 175 is the one with the power! Short stroke, cam, high compression pistons (198cc), lightened clutch, high perf valetrain and oversized valves!
Just to brag a bit.
Wow man that's impressive. Bragging is allowed if you have the HP to prove it :) I'm getting there.
Where did you get your pistons?
acm177 said:
Arias pistons, via Mike Riddle.
How do Mike's pistons work in a 175 head? They look to be very tall so I imagine that it takes a lot of spark advance to work well.
What I would like to know is how Mike's 175 bike won all three classes at Willow Springs...with Billy Hamill aboard?
They are pretty tall and the tolerances are very close inside the combustion chamber. I was worried about the spark plug touching but I clay checked it when assembling and its just enough. Mike did some precision R&D on that design.
From the seat of my pants; the further I advance it the better it works with the cam from 7-10k. I had it set at 47 degrees and have nudged it gently past with good results.
It will hold an idle just above 1500 rpm but the more I nudge it forward the more I have to feather the throttle or readjust the idle... Which is to be expected.
Speaking of idle, can you guys walk me through the procedure for dropping a high idle?
I'm idling around 3k now. Bike runs strong and has solid throttle response in all gears at all revs...just never drops.
I am at stock 175 jetting, air screw 1.5 out and mixture screw 4 turns out from bottom. I tried the procedure in the manual to back out the air screw until highest idle is achieved then adjusting the mixture screw to bring revs back down...the revs I can get down but the throttle won't respond and it eventually bogs if I don't keep the throttle cracked.
Also, it sounds like I'm pulling more air in via the right carb (just makes a lot more sucking noise) even though the carbs are set at the same screw positions...and synced with Popsicle sticks.
What about the idle screws. We talked about backing out till they bottom out. The cable adjustment could be keeping it up a bit
Idle is done throughout the pilot, air screw, idle screws and timing. Your timing is good, your stock pilot is fine.
You and me need to throw our bikes on the dyno and have tuned
Yeah I pretty much backed them out till they no longer had an effect on the slide then came in till they barely raised. That ended up being about 4.5 turns out. I was able to lower the idle a bit and brig it in to 4 turns out without throttle effect so I kept it there.
You're in PA, I'm in NC. Northern VA sounds like a good halfway spot for a dyno party haha
