Re: "Patina" The 1973 CB175 Cafe Racer
HerrDeacon said:
Just looking back at my text and my wording may confuse a bit. By 'move it down a notch' I mean that the needle clip would be one notch lower (which raises the needle). I read teazer's response and realized how my wording may confuse so just wanted to clarify.
Here is a generic diagram to help.
This is probably me not understanding. But if I knew I was rich, I would move the clip up to drop the needle to get it to the lean side if that diagram. I think...
But either way, per your and Teazers recommendation it's an easy switch to try both ends of the spectrum.
Yes, that is correct, but I thought you said it ran better mid-throttle if you gave it a bit of choke? If so, it was lean to begin with and you need to richen it up.
Ok that makes sense. I originally said that I thought it was lean because of what you just said. Then Tex said to look at the plugs and that showed a rich condition. But then Teazer said that mid range plug reading is very inaccurate.
Haha.
So I think if the plug reading is inaccurate then yea you are spot on, I would need to richen it according to the performance difference I was seeing.
Here's the deal. Like most things in life, things are not always as they appear. In this case we mean raise the clip to lower the needle.
With plugs, what we are looking at is how hot it gets. Let's say the tip reaches say 900 degrees C at high RPM and full load which is where we do a plug chop. At half throttle and lower load at lower revs that same plug tip might be only 400-500C. At that temperature it isn't hot enough to burn off carbon and other deposits, so it reads as rich.
With that same motor the tip might hit 1000C slightly lean and maybe only 800 slightly rich or very lean (incomplete combustion). Load will make more of a difference as a rule than jetting to how a plug looks.
That's also why when we look at a plug on a street motor all we can tell is that it was blacker or cleaner than some other time we looked. If we jet down, it will look cleaner and leaner but that's no indication of the right air:fuel ratio that our motor needs. Plugs today self clean over a wide temperature range, but at low load they will always read darker than we expect and unleaded fuels leave more soot than leaded fuels and need a higher plug temperature to clean themselves.
Just to complicate things, we rarely run motors at Stoichiometirc 14.7:1. They make more power around 12:1 and are most economical at closer to 16:1. That's why it's best to run the bike on a dyno and get an air:fuel chart at full throttle and then at half or 3/4 to see what's going on.
Here's a couple of links about plug temperatures that you might find interesting
http://www.stealth316.com/2-sparkplugtech.htm
http://www.globaldenso.com/en/products/aftermarket/plug/basic_knowledge/heatrange/
Thanks Teazer! So for the dyno...does it depend on your intentions going into the session as to what you are after I assume?
I'm not shooting for all out power, kinda a mix of power and efficiency... So when I dyno, are they essentially going to mess around with the air/fuel in attempt to achieve the goal you're after? I assume so, like in Tex and zeke's case.
I've been working on other things lately but decided to get back at this and figured out.
For kicks I put the jet needle clip all the way at the bottom position, raising the needle. I am running 90 mains right now, and still can't get the thing to pull. Started out at the middle clip...
Middle Clip: Bike can reach redline if you slowly make throttle adjustments. Any blip adjustments at mid throttle it doesn't like much. Runs better with choke.
Needles at FULL BOTTOM CLIP POS: Bike won't idle...idle drops too low to maintain. Demonstrates same behavior as middle clip but much more dramatically.
Needle at FULL TOP POS
Bike still runs stronger with choke cracked. Any sudden full throttle movement the bike loses all power. Bike runs OK up to about a quarter throttle. If I baby the throttle and gradually increase to full, speed increases and the bike will pull but low power.
I need to dyno...also should check timing to make sure nothing has changed.
On a dyno run we look to see the air fuel chart as well as the HP line. If the A:F is too lean, we'll typically add a larger main jet and see what that does. Rinse and repeat until it works well and the A:F line is within reasonable range. If it's way lean or rich at the bottom as the operator rolls it on, we change out the pilot jets.
If we have to tilt the fuel curve, we either change air jets or needle jet spray tubes or change fuel level. Sometimes that's all it takes to get back in the ball park.
In your case, needle position doesn't make it better at all- responds to choke. That suggests that it's lean. After you double check float height with the carbs AT AN ANGLE - NOT UPSIDE DOWN, try to adjust the pilot jet air screws to make it richer at the bottom end and see if that will add enough extra fuel further up the range.
If that helps but not enough, try some 92.5 or 95 main jets and see how it responds to those.
That makes sense to me. I think I really need to check timing before I go down this road. Thinking back these are the same symptoms that I experienced when I was firing late.
Also the bike really didn't like that trailer ride and the bike was running fine before the ride to the bull city rumble show. Wonder if the bumpy ride knocked it out of time...? Seems hyper sensitive.
Well, it's a little better. Timing was off I guess. I can't figure this out. Static timing I'm supposed to "fire" at the T or F or inbetween and then at revs I'm supposed to be between the full advance marks. But when I statically time the bike at the F the bike can't even start.
If I time the bike statically at the full advance marks, starts just fine but it still stumbles fairly violently at high revs.
I feel like I could even advance more but I'm afraid I'll burn a hole in the piston. How many degrees past the full advance can I go without worry? Or at all?
when you use the strobe while running and up over 4000rpm is the timing still between full advance marks ?
Doing that next. That's unfortunately a 2 person job with a wet stator and a bump start :)
Ok did dynamic timing again. Even though it was statically timed at the full advance marks, the dynamic timing test showed that the pointer rested right after the second full advance mark (more counterclockwise mark).
Meaning I'm a little beyond "full advance" by like 3 degrees or so. So that checks out all the way up to about 6k rpm. It holds steady from 3-6k. So I could retard it a bit to bring it right on the money.
Still doesn't explain the sudden loss of power right when you get to higher RPMs. Also I can run to redline in first gear but not really in any other gear.
we are 10-12 degrees past the furthest advance marks. We asked the same question and the answer you will find on the Dyno. First you can keep advancing as long as you continue to make power and as long as your air fuel ratio is in the 12-13:1 range. We make the most power as long as we are closer to 12:1 fuel ratio.
Ahhhh ok I didn't know this was involved in the dyno process as well. I thought they would set the timing where it "should" be and then tune from there. So they will keep advancing the timing until you stop making power and then carb tune from there?
timer i would suggest with the stock motor you stay with close to stock timing,your running issue is not timing related,in my hoe
Not strictly true.
The advance limit is determined by the amount of heat generated. Advancing the timing causes additional heat within the engine. The burn starts sooner, so the heat that would normally be going out of the exhaust is now still contained within the combustion chamber. This leads to higher overall temperatures. Past a certain point, detonation, and even pre-ignition will occur.
This issue can be tackled in a number of ways. In no particular order:
  • Additional cooling - Bigger radiator, more/bigger fins, etc
  • Additional fueling - Higher fuel-to-air ratios result in gasoline evaporating, but not burning. This draws heat out of the combustion chamber.
  • Water/Meths Injection - Injection of water and/or methanol into the intake reduces temperatures as the liquid pulls heat from the chamber as it vaporizes.
  • Higher octane - Higher octane fuels are harder to ignite, so detonation and pre-ignition are less likely. You're not dealing with the extra heat so much as changing the point at which the heat becomes an issue.
  • Dynamic timing retard - Modern cars use knock sensors to dial back the timing if/when it becomes and issue. Other sensors (such as boost sensors for FI engines) can do this as well.
So yeah... keep advancing so long as you can handle the heat and it's creating more power. There will be a point at which further advance will rob the engine of power rather than provide more. This point can usually be identified using a remote IR gun. Exhaust temps (under load) will continue to decrease as timing is advanced. They will start to increase again as timing advances past the sweet spot.
Aha I think I can get my hands on one. Thanks Sonrier!
Can this be done in neutral after the bike has warmed up a bit? Any recommended procedure there?
