I have a little more progress on the tank. I welded a plate over the rear tunnel on the tank. It didn't go down around the frame in the rear and I wanted to cover up the hole. It also gave me a place for the rear mount. I've cut off the front mounts. The mounts need to be about an inch higher. It just makes the tank sit alot better on the bike. I'll weld a couple of bolts as mounts with the threads cut off and then use the stock rubbers. Just in case someone is using the CB 200T tank on a 360, they should mock it up with the engine on the bike. Otherwise the pitcock could cause clearance issues. I'll try to get a few photos up tomorrow. Troy
