Father Son 75 CB200T Rise From the Ruins
teazer said:
While I would normally agree with what Sonreir said, I'd suggest that you see what the dyno says. Max power is usually made with a slightly rich mixture, but who knows what your particular motor needs to get the best sustainable power. When you do a long high speed run, a little extra fuel is often useful to keep temperatures down, but it all comes down to what your motor needs.
dyno is next. I think we need to address the temperature issue with an oil cooler in the near future. How much sucking does the vent hose do at high rpms??? Do we need to have a pcv valve on it?
Edit I think I found the answer....kinda steep and then add an automotive pcv valve?
So what happens internally when the breather hose starts sucking instead of venting? But especially in a cb???
Hey Zeke and dad ;) Was wondering if you guys found a big difference in the electronic ignition over the points. If so, what are the benefits other then the obvious ones?
On most engines, pumping losses at high RPM are a pretty big deal. On a 360° twin engine, such as the CB200, pumping losses are even more of a concern. It would make sense that some sort of one-way valving system would be a good idea.
thank you Sonreir! I have read the crankcase breather is basically worthless and that the oil plug breather with a pcv valve is a good fix.
We were able to observe the oil pumping with a half plexiglass and the upper part of the crank was spitting oil at us. We have pulled the tappet covers as well and have good flow there. Heat seems to be the main design flaw of this motor. We pulled our old pistons and there is a concave dip in the center of both pistons due to excessive heat?? We were comparing the large dome of the stock pistons to pictures of the 58mm kx550/s90/atc90 pistons.
Now we need to learn about combustion chamber shape and what we need to do for our new head.
We also learned our Cb has a single gear on the clutch unlike the 175 has one you can remove to lighten the clutch basket. We haven't researched if the 175 clutch basket will work on the 200 motor. Sorry I am rambling.
We have addressed most of the ignition issues. The next most beneficial improvement seems to be addressing the oil temperature??? That will allow us to keep tuning for speed without blowing her up and saying, "wow if we only took care of the heat issue."
http://www.ebay.com/itm/Trail-Tech-TTO-Temperature-Meter-Black-Digital-Gauge-14mm-Spark-Plug-Sensor-NEW-/380682489262?pt=Motorcycles_Parts_Accessories&hash=item58a271cdae&vxp=mtr
Just sayin'... ;)
YES! The spark is not trying to jump to other places it shouldn't! We observed random sparks jumping from the points to the points spring. The Dyna S Gl1000 points plate required no mods and is easy to advance and retard.
Just sayin'... ;)
thank you!
So we are meandering along researching crankcase oil breather plugs and discover a name that is probably common to y'all. Franco Cappellini which leads to Ebay which leads to the best motorcycle site on Facebook
Cappellini's oil cooler is a work of art. Pick of cb250.
Picture of Cappellini helping Team Hansen at Daytona. Interesting trivia Teamhanseneurope.com takes you to Capellinis site. Love the shape of that fairing.
https://www.facebook.com/pages/Team-Hansen-Honda/116916108330930?sk=photos_stream
Pictures from Team Hansen. So we learned kinda what our exhaust ports should look like.
Sonreir said:
So it looks like they've tried ovals and Ds... I wonder which turned out better?
i will ask. Both Teazer and Michael Moore said the floor needed to be raised and on the bench using clay the exhaust port performed better smaller...
Oval at the bend to avoid breaking into the spring pocket and D at the gasket face to reduce reversion.
But keep in mind that changes will be small and only if that is the limiting factor. Crankcase breathing is important and so is valve control. Crankcase breathing can be improved by allowing gas to pass more easily from one side to another and the 200 already has a larger top breather hose than 175 or 160 motors. A filler cap breather also helps, but it needs to be as big as possible.
Did you see the velocity stacks on the team Hansen site? Terry spent a lot of time testing to find ones that flowed best. They only add a couple of percent, but it all adds up. He's a car guy and has applied some of the tools and tricks he learned with cars.
It's not just a case of copying what worked for another racer. Terry tests and modifies and re-tests until he gets what he wants. Start with books and articles by David Vizard and AG Bell. Then build a flow bench and have fun.
One other thing to focus on is making sure there is minimal friction in the wheels. They should spin freely.
LOL I knew YOU would notice the front rotor! So I decided to threshold brake from 75 and had a catastrophic front brake failure. The spring on the mechanical brake failed and I found out as soon as I tried to accelerate! Switching to a drum
Yes we saw his velocity stacks but we like the ones our friend Teazer has tested!
He is knifing the motorcycle cranks like his car cranks! I could spend hours looking at those pictures.
our first Vizard Book
well first off you have a link in PM . Have a conversation with Ryan at that email . Both Tim and I have and examples of his work and are more than pleased , much more than pleased , more like amazed . Order the parts , close your eyes , sign the check and be amazed . http://www.707racing.com/
The head is junk cut it .
With a crossover pipe near resonant point (28" or so ) there is a low pressure just forward of the crossover .
http://www.ebay.com/itm/Standard-Motor-Products-AV9-Air-Injection-Check-Valve-/370860105032?pt=Motors_Car_Truck_Parts_Accessories&hash=item5658fc1d48&vxp=mtr
install one on each pipe and "T" them into another check in the crankcase instant passive vacuum pump .
A properly designed reverse cone megaphone on each pipe will make the vacuum effect even more pronounced .
Anything from Hansen's CB450 projects is interesting reading .
Enough for now
~kop
Enough for now
~kop
First things first! Thank you Kop for the introduction to Dutch at airtech. The Peel 1 will be here in 4 weeks! Dutch also sold us the windshield they used for mock up on Scurria's Peel 1.
We will use the junk head to practice porting on. Then we will cut it and see how we did!
The bad news is we blew this months budget! The good news is we have a savings account for lucky that is still in the black. We save and then buy...gotta teach my son NOT to go in debt! All my banjo, mandolin, and guitar teaching money is for our "home school" budget ;) cue deliverence...and yes I play my banjo in my boxers :)
I have 707 on the list to contact from our phone conversation! I research things to death. OCD.
It took me 6 months to research my first bed when I got married.
Zeke is ecstatic about the Peel1 and we saw a similarity with Hansens Daytona race bike fairing. Zeke informed me he also wants to road race Lucky :)
Give us your feedback! Pistoleros with Piston Problems?
On our last Dyno run we started with 12 whp and tuned to 15.2 whp and we ended up being jetted below stock! We were puzzled. Our dyno guy told us to jet down to 80's since we were still off the chart rich! We stopped on our third run to figure out why. As you know we didn't just do the standard slap on bigger carbs and cam. We wanted to see how much we could tune for less. I want my son to put his maximum into his minimum.
We are running stock carbs, valves, .75 over honda pistons, racing valve springs, stock cam, and racing timing chain. No porting...yet.
So we tackled things surrounding flame propagation. We installed our dyna S, iridium plugs, non resistant plug caps, changed to 89 octane from 93, indexed, extended our velocity stacks (which probably increased the problem), advanced our timing. Now our little 18mm carbs are flowing 208 dcm/sec @ 10,000 RPM and we are 160 dcm/sec past our valves....so we think we know the problem and it has to do with our pistons. You can have a long stroke but the wrong shaped piston...such is life.
http://youtu.be/bblDZz6nxlk
Video shows up as "private" :-(
Hansen fairing is a copy of the one that John Cronshaw developed for his BSA DBD34 based race bike. John took the same idea as the Peel to cover hands and arms. http://www.flickr.com/photos/32315868@N03/3316949797/
There's a similar looking fairing on Steve Maney's Norton too. http://www.flickr.com/photos/g1000seesee/3233988610/
Pat Mooney uses a Peel on his Petty Manx. http://i215.photobucket.com/albums/cc269/photomd/Vintage%20Racers/303DH12.jpg
