Texasstar
Can't is a four letter dirty word
dyno is next. I think we need to address the temperature issue with an oil cooler in the near future. How much sucking does the vent hose do at high rpms??? Do we need to have a pcv valve on it?teazer said:While I would normally agree with what Sonreir said, I'd suggest that you see what the dyno says. Max power is usually made with a slightly rich mixture, but who knows what your particular motor needs to get the best sustainable power. When you do a long high speed run, a little extra fuel is often useful to keep temperatures down, but it all comes down to what your motor needs.
Edit I think I found the answer....kinda steep and then add an automotive pcv valve?
So what happens internally when the breather hose starts sucking instead of venting? But especially in a cb???
