Father Son 75 CB200T Rise From the Ruins
pacomotorstuff said:
The "skinny" Peel fairing is a great addition to your bike, but unless you're keen as mustard about unbolting the front forks and wheel every time you so you want to get the fairing off, you'd better look at modifying it like Bill Anderson's fairing - ie, make a nose and belly split.
I didn't look too closely at the vid so I don't know for certain what Bill did under the lower fork yoke, but I modified my fairing mould so it's a 3 piece - a nose, a belly and a little "T" piece, all with joggles at the marryups to allow the fairing to be Dzus-fastened together just like a modern fairing.
I haven't read all of the posts on this thread, but when I looked at your 2-into-1 exhaust system lashup, I wondered how you were compensating for the fact that the right pipe is around 5 inches longer when the exit ends of the pipes are at the same point - the right side header has to travel a lot further to get to the left hand side, right? I'm fighting the same problem with my CL175 twin (street bike) - I want the head pipes the same length. In my case, I'm using two separate mufflers so not that big a deal except for the stagger on them looks a little odd - so maybe a balance tube?
You 2 have done an outstanding job on this project - incredible amount of work and detail. Beautiful.
Pat.
Thanks Pat! When we put the Skinny Peel on it will stay on...until we need to change motors or other things we can't get to My son doesn't want to do a two into one. He likes the scrambler exhaust so we will see what happens with the Peel. He wants to go with two short cones like this CB.
The first goal is to DO THE TON with less. So we are almost dialed in with a basically stock motor as Teazer likes to call his .
We have not ported not are we running a better cam...yet. We have a 200 head coming in the mail to dissect with a band saw.
Pretty much the same look as my bike but as I said, to keep the headers the same length, the right cylinder's meg is almost 5 inches further ahead than the left cylinder's.
Bandsawing a cylinder head... hmm, haven't done that in awhile.
Have fun with your ride.
Pat.
Well we bought a head for 19.00 bucks plus fit in a box USPS shipping off flea bay... and I think we may rebuild it vs cut it in sections. Oh did it run lean one side??? But we are gonna want to replace the guides and the seats any way with bronze nickle Need to weld up the combustion chamber and re grind...looks like an opportunity to make the combustion chamber flow better! Teazer is right the exhaust and the intake look identical to the section of the 175!
What do you think? Should we rebuild it and make it better?
More or should we cut it into sections...
Texasstar said:
I love this guy! 40 year love affair with his Norton and I met him on this Forum! And a full size Peel fairing!
http://youtu.be/jmbKDIKDKFo
Nice vid! haven't been to El Mirage in a while, did 113mph on my stock (with 17's and slicks)KTM 525 there once and my son got 63mph on his modified klx110.
Interesting thread you've got going here.
thanks Johnu we are looking forward to a little bonneville father son bonding also! 3 years!
Sonreir said:
Give it a couple of years and you'll be modifying CB200 heads in your shop for spare $$$ on the side... lol
Have you seen the Build Milwaukee Program? Guys like YOU mentoring inner city youth? I could get into that...we could have teams and then race each other! Teazers Tonners vs Sonreirs Sonics vs Kop's Cosmic Kids...
Our local shop made us a deal on a digital timing light because nobody buys them. We really like the Rpm function. Now we are dialed in TDC. The Dyna S is super sensitive! The digital advance on the Actron 7539 can be advanced in tenths. We need to buy another cover we can notch so we aren't losing oil every where. Ductape and plastic worked for about 5 minutes. The Dyna s is super sensitive! We are trying to dial in our total advance to 45-47 degrees. However we are gonna wait until we get on the Dyno to advance it. We marked the Fire with red to make it easier to see.
Lucky's best run so far! Timing dialed in. (Thanks Teazer) We installed the following:
85 main jets
Dyna S electronic ignition
17 tooth front sprocket
Iridium plugs
Non resistor plug caps
Bought a digital timing light (Zeke says that tools don't count toward our monthly budget)
10w4O partial synthetic
Extended our velocity stacks to 120 mm
http://youtu.be/ZFzdDls2BhE
Plug chop on 85 jets. What do y'all think? Revved great!
Indexed plugs.
Ah now I'm jealous! Can't beat racing or riding with your son. Would love to go to Bonneville although my son just joined the navy so I might make it out there with my dad. Good luck.
Still too rich.
Here's a plug that's just about perfect (has had the threading and side strap removed):
VERY light tan color, with a smoke ring around the base.
While I would normally agree with what Sonreir said, I'd suggest that you see what the dyno says. Max power is usually made with a slightly rich mixture, but who knows what your particular motor needs to get the best sustainable power. When you do a long high speed run, a little extra fuel is often useful to keep temperatures down, but it all comes down to what your motor needs.
Thanks...Zeke told me he also wants to road race Lucky. So we need to find a school that will take him. Texas once had one of the best farm systems. I have an idea we are gonna be setting up cones in a big parking lot. He grew two inches this year and Bilt has pants to go with his jacket which should be good up to a 60mph spill. I took Lucky out the other day and did a little threshold braking and the front cable spring failed and locked the front wheel up...that mechanical disk has to go.
We need to find a safer place for Zeke to practice and I have limited him to 55 mph. Of course he pushed that limit. We need a two mile straight run. Any ideas? The salt is totally different than the pavement. We have the greatest twisty roads in our county in Texas but that is no place to be at speed and pushing things too many uncontrollable variables. We have track days in Texas...on well we will figure it out.
We have met obstacles
