Father Son 75 CB200T Rise From the Ruins
How did you conclude that the smaller jets were the result of piston and combustion chamber shape? What changes jet sizes is changes in differential pressure over the jet. If your bike needs smaller jets (than stock) then either the jets are flowing more than a stock jet is designed to flow - OR gas velocity through the venturi is higher than stock leading to a greater pressure differential.
If you compare that motor to others, it's a whole different issue, but yours versus stock is more gas flow relative to air. If the gas analysis on the dyno shows normal CO and CO2 levels but elevated HC levels, that's unburned fuel and needs a change in air jet and or emulsion tube design.
Rich will show up as low Lambda or high CO (insufficient O2 to complete combustion).
Raising compression helps if the squish band is working, and larger air jets usually help to break up droplets. What pilot jets are in the carbs? It may be that they are raising the fuel slope.
zeke just unlocked the video! This is how we came to our hypothesis...it is in the Video :)
On your dyno runs, try without any stacks, with just the 750 stack and the new longer stack to see what difference that makes. You could also try more (or less) ignition to see what difference it makes.
Thanks for unlocking the video. Your pistons are the same as any other 200 and should not change jetting. They are not as bad as some I have seen. Maybe the larger bore is just pulling more air in and proportionately more fuel.
Do you think we should jet her first and trust the dyno and then play with the velocity stacks and see what happens to the fuel mixture???
Would removing the middle of the 8 in the Venturi of the 18mm carbs slow down the velocity?
That makes sense because what made me think it was the piston shape was what you commented on in this 175 string. So the 200 pistons are better than the 175 piston shape?
Contextually lacking. I should have made that reply clearer that aftermarket race pistons for CB160/175/200 engines typically have tall crowns - much taller than stock and they make combustion worse than stock.
Your pistons are fine for now but squish clearance is probably excessive. If you can tighten that up, it should help with turbulence in the chamber
Exaggerated crowns can harm cylinder filling as well, especially in a hemi head (which the CB200 has). If it can be arranged, having the intake valve dwell in the piston flycut (during the intake stroke) will help, but it's not a trivial task and can sometimes involve compromise in the duration and lift that you wouldn't normally undertake. Given that these motors respond well to compression increases, it could be worth it though.
You were in context I took it out of context. Thanks for the clarification!
So with excessive squish clearance the fuel is standing at the wall like a teenage boy at a barn dance and then leaves the dance wishing to have been lit on fire and ends up exhausted? :)
1. How do we calculate the correct squish for Lucky so that we gain maximum power at the end of the torque curve? I bet we are about to learn that in Vizards book?
2. Is there a better combustion chamber shape for the little Cb's other than its hemi shape?
3. Where do we learn to do this ¥
We need to go learn about intake valve dwell...and fly cutting :)
I grabbed a set of copper head and base gaskets to set squish clearances. I got 3 of each in varying thicknesses.
I set the jugs close to 0 deck height relative to the piston. According to my notes I was +.002" out of the hole in the setup I purchased.
I used a .026 base + .042 head gasket, which give me around .040 of squish. I think the stock head gasket i had measured was around .060" if not larger?
(marked as B)
If any of this math doesnt add up, it was a scratch pad for ordering gaskets.
I did some measuring after assembly that's on a piece of paper in the garage.
== Piston wobble ==
Right Piston:
Rear: .023 @0 deck
Front: .022 @0 deck
Left piston:
Rear: .025 @0 deck
Front: .025 @0 deck
== Piston specs ==
Arias Min Piston To Head w/ Steel Rods .040"-.050"
Right piston Out of hole + rock / 2
@ .026" + (.005"/2) = .028(5)
== calcs ==
Base Gasket: Out of Hole + Head gasket = Squish clearance:
BG OH HG SQ
.021: +.005 - .063 = .058"
.021: +.005 - .050 = .045"
.021: +.005 - .042 = .037"
.026: +.002 - .063 = .061"
.026: +.002 - .050 = .048" A
.026: +.002 - .042 = .040" B <--
.032: -.004 + .063 = .067"
.032: -.004 + .050 = .054"
.032: -.004 + .042 = .046"
Squish combos: .046", .048", .052", .054"
(marked as B)
== Piston wobble ==
Right Piston:
Rear: .023 @0 deck
Front: .022 @0 deck
Left piston:
Rear: .025 @0 deck
Front: .025 @0 deck
== Piston specs ==
== calcs ==
BG OH HG SQ
thanks Acm...did you mill your head?
Our aftermarket base gasket measured .55 mm (.0216 in) and our head gasket was 1.45mm (.057 in)
And I don't know what our out of hole was. I can tell you what our out of pocket is. :)
I think I've heard this somewhere before ...
~kop
~kop
So let me see if I understand this... A hemi has a different definition for squish than other shaped combustion chambers????
"For those of you who have gone backward in time, seduced by bathtub "hemispherical" combustion chambers, this calculator won't do you much good as their "squish is defined by the peripheral intersect of the spherical piston dome and the dome of the combustion chamber...There is no "flat" area of the head and piston to measure. Whereas we all love "Hemis" and all this word stands for, from Richard Petty and the Superbirds to all the current supercharged Rodeck, Keith Black, Ed Pink, and Arias hemis, it's not the chamber design we see in modern pushrod engines like in NASCAR. Swirl, turbulence, squish, quench, smaller combustion chambers, and higher compression ratios with narrower valve angles are the norm these days...not whacking big relief pockets into domed pistons. This is the era where we want minimum surface area on our piston tops and where we wish to direct our "burn" to the exhaust valve, not to the far reaches of the combustion chamber. Hemi designs compromise the combustion process."
http://www.rbracing-rsr.com/squishcalc1.html
1. So technically you can have a 0 squish band in our hemi.
2. Taller dome pistons are used to reduce overall squish according to this definition.
3. According to Sonreir's how to build a functional cafe racer...technically we can remove the total base gasket thickness and reduce overall squish by .55mm (.0216) inches with no adverse effects since this has been done for decades.
4. A bad relief cut for valves clearance can be a place for detonation?
The thinnest Cometic makes for our Cb is .0127" base gaskets and .0254 Head gasket...lol
Yes, the head was milled flat. I cant' remember how much it was decked... off the top of my head.
Squish still exists on a Hemi head, it just takes a slightly different format:
In the above pics, you can see the angled portion of the piston before it meets the crown coincides with the angled portion inside the head. This channels the mix upwards toward the top of the combustion chamber (closer to the spark plug and exhaust valve) as well as introducing more turbulence (increases burn rate of the mixture) and helps to eliminate hot spots. The difference in angle between the head and the piston should be about 7° with the opening of the angle expanding as it points toward the interior of the chamber.
The maximum amount of clearance between the head and piston where the squish band begins should not exceed .040" (this is the measured deck height for most hemi engines). I'm aiming for .020" on mine once I get it dialed in.
Hold on a moment.
CB honda twins do not have a full hemi quiescent combustion chamber. They have a narrow squish band like the pic of that EVO cross section. To get compression up, we start by machining the pistons to get the squish band to the shape/angle we want and by so doing, the crown gets to be slightly taller but only by say 0.5 -1.0mm
Step 2 is to deck the block so that the outer edge of the piston is flush with the gasket surface.
Step 3: your head ( well the bike's) goes on a milling table and the mill is centered using the barrels and dowels so that the next cut is concentric with the bore.
Step 4: machine a new squish band into the head at 1 degree larger than the piston. There must be a difference to maintain the correct mean squish velocity, but it's only around 1 degree.
Step 5: machine "some" off the head to bring the width of the squish band back to the same as the bore. If you plan on machining more than about 1mm off the head, might be best to reverse steps 4 & 5
Get a new gasket made between .030 and .040mm thick. Less than that and the piston will hit the head on the exhaust stroke. Two strokes don't but 4 strokes have that lazy exhaust stroke with no compression to cushion the blow. In general, the narrower the squish band, the tighter it can be (within limits) There is software out there to calculate MSV. Bigger engines need more squish clearance as do engines with wide squish bands.
That should leave the valves just touching pistons around TDC. You can either machine deeper pockets for the valves or recess the valves slightly into the head. We have to do both to get enough clearance.
You will also need what used to be called Fire Notch to clear the plug which will now have negative clearance to the piston.
You will also notice that the EVO head is not perfectly round but the sides of the chamber are narrower than the dimension across the valves. It's a multi-spherical design that is somewhere between a bathtub and hemi and works quite well. That can be achieved with a little weld after you take out the valve seats.
BTW, what are those pistons or who sells them?
Sonreir said:
I'm not a slow learner... ;)
I can be if I don't experience it!
Sonreir wouldn't you want to also hold a squish tolerance at the top of the piston and the hemi? I am thinking out loud...Is the hemi inefficient around the horizon of the hemisphere? What squish shape creates the perfect turbulence for combustion in a hemisphere? I hope these are not stupid questions.
You want a slight angle in order to channel the mix in the correct direction. If you were to keep the tolerances equal throughout the band, you're pushing the mix in all directions (even up against the cylinder walls) when the idea behind the squish band is to concentrate the mixture into a single, dense, location. By creating an angle of a few degrees between the piston and head, it creates a lower pressure area. This is what causes the channeling action toward the center of the combustion chamber.
The goal of the squish band is two fold: First, create turbulence. Turbulence mixtures burn faster and a faster burn means high BMEP values as well as less residual heat transfer to the engine components. Second, concentrate the mixture into a more ideal location for the burn; closer to the plug and closer to the exhaust valve. Keeping the burn located away from the cylinder walls and head surfaces prevents heat transfer (the goal is to keep the heat inside the combustion chamber because heat is power!) As an added bonus, a good squish band will also help to eliminate hot spots within the chamber that can lead to preignition (especially true on iron heads, though you won't have to deal with this).
As for efficiencies, the hemispherical shape is actually the most efficient shape for combustion (when you remove all other variables from consideration). The Chrysler 300 was a ground-breaking vehicle when it was released and much of its performance came from the introduction of the hemi. Unfortunately, use of a hemi head requires a lot of design compromises in other aspects and so they aren't found in many engines anymore. They have difficulty breathing because there isn't any really "good" spot to put the valves. They usually require a large include angle which leads to shrouding and other issues. The best way to work with a hemi head is to take advantages of its strengths and that strength is its resistance to detonation. Spheres have the lowest-surface-area-to-volume ratio of any three dimensional shape and so it means that when compared to other head designs, hemis can stand up to a hotter burn (more fuel/air mixture when compares to less heat transfer to the cylinder head). This means more compression. With a good squish band and high octane fuel, 13:1 or even 14:1 is doable on one of these old blocks. I'm running almost 12:1 on mine right now (stock was 9:1) with no ill effects.
Of course, more compression usually means domed pistons and that brings a whole other set of concerns to the table...
aha moment...i have the picture in my head :) Do you have the stock squish tolerances? It must be very high if you can safely reduce a full 1mm from the head by adjusting the head gasket as Teazer suggested to .030-.040 mm.
Does this look right?
.949 mm gasket reduction
My volume of combustion is 12.735 cm cubed before gasket thickness reduction
41(56.25/2)^2 x pi +12735)/12735=9
The gasket size reduction reduces the volume of combustion by 2.35 cm cubed
.949(56.25/2)^2 x pi=2358.31/1000=2.35 cm cubed
The new volume of combustion will be 10.385 cm cubed
The new compression should be 10.8-1
41(56.25/2)^2 x pi + 10385)/10385=10.8
That being said for 60 dollars compression is raise by 1.5 with reusable copper gaskets...pretty good bank for the buck if my math is correct.
