Father Son 75 CB200T Rise From the Ruins
I want my son to listen to what the bike needs within the contraints of working with what you have. For example we did the math on the intake needing to be 12.5 inches long but on the dyno it was .6 HP gain with the cb750 velocity stack on the carb with stock intake length. We ran lean with the velocity stack intake long and rich with the velocity stack just on the carbs and then the kicker with an increase in HP. Apparently Lucky is telling us she needs something else to go faster.
Yesterday on the dyno for some reason one of the velocity stacks kept falling off at the extension. I put it on 4 different times and finally at the end of the runs pulled the extensions off and put the stacks on the carbs. Serendipity? Or was lucky telling us something. A .6 bump in HP is a lot for this little engine.
How important is dyno time? Look at the difference between our very first run and now. The first run was doing the status quo: remove airbox, add filters, jet up. 12.4 whp
Our last run was 16.5 because Teazer told us to listen to what our bike needed on the dyno (and Lucky kicking off her velocity stack extensions. ;))
We got all the files from our dyno runs so this is from June 13, 2013. Here is the chart comparison
Run 1 uni filters over cb750 velocity stacks with 100 jets off the chart rich
Run 2 no filters with cb750 velocity stacks 100 jets still off the chart rich
Run 3 cb750 velocity stacks 90 jets way rich right pipe
Run 4 cb750 velocity stacks 90 jets way rich left pipe
*timing slightly advanced 93 octane, 20w-50, stock points, stock intake length with cb750 velocity stacks.
This is the comparison with our timing being advanced retarded and then the static. Red is static, I will post the degrees later we advanced timing a quarter inch from our already advance position(blue). We then split the difference between our statics and what we road in advanced (green) Then returned Lucky to static for the last run.(Red)
The purple mark is static, the lime green advanced, the dark blue was were we started the dyno day, light blue way advance we lost 1hp
17/35 gearing change in fourth gear. Our best real world has been 76.
Why is the data we have been provided different than what was on the dyno screen at the shop? Look at run 6 on both. 15.38 on one and 15.69 on the other?????
can't wait for the fairing
One is the measured value, and the other is corrected for climate. You can see the correction factor used for temp, pressure, and humidity - SAE 1.02.
15.38 * 1.02 = 15.69
thanks!
Strangled...the data doesn't lie
SONICJK said:
You're getting way rich up there on the top end 8)
yes sir! We are going back to our 85 jets. This was run 16 with our velocity stacks extended so that we had a 12.5" total intake and our timing slightly advanced (lime) as you can see it took twice as long to get to 9.5 k. Teazer was right if the advance isn't dialed in to 45-47 total advance it hurts you. (If you click on the data it will orient itself)
So we like big butts in Texas. We found out a big butt will make you go faster... Who knew? So which big butt do you like the best to go fast? And No Teazer it doesn't make your Texas gal's butt look big ;) lol pinkpossum roflmao. The 250e was built by Teazer
I love those old dyno charts.
They come form factory service manuals from back in the day.
They are so much higher than any real world bike that it makes one wonder WTF they did. We do know that the data is at the crank and was probably measured on an engine dyno and "corrected" to get theoretical crank HP with no alternator or drive train drag.
In the real world, rear wheel HP is considerably lower than the charts suggest. Factories used to exaggerate the power claims for years until they finally stopped publishing those works of fantasy. They look good though. :-)
The seat on that TZ is a stock TZ C,D and E seat. Vesco developed the big butt seat for Daytona and it probably worked. The lip is an anti drafting device to make the air turbulent behind the bike to make it harder for riders to draft. It probably makes little difference to top speed.
They are big seats but quite narrow where they sit over a TD3/TZ/RD frame. They should fit on a CB without too much trouble. I can check if you like. I have a spare 160/175 frame and one of those seats on the shelf for another project.
Looking at the data, I'd suggest a slightly larger main air jet to tilt the fuel curve.
Of course they are not available from Keihin or Honda but the pressed in jets can be removed with careful work with an EZ out. Then drill it 0.2mm larger and carefully press them back in.
Or get some new ones machined up. That's what we did with Cb77 carbs on our 175.
Teazer picture this...a ten year old reading David Vizard on the back porch Saturday morning because of you...and being grounded from all electronic devices :) thanks we will talk to our neighbor Steve. He gets giddy taking Lucky's parts to his shop.
We are going on a field trip to a porting guy of my friend who races dirt midgets with motorcycle engines.
