Father Son 75 CB200T Rise From the Ruins
Sonreir said:
Does this fairing make my butt look big?
lol
I live right around the corner from L&L. I walk there and pick parts for mah mates in Phoenix, Austin, El Paso, Cali etc. Funny how mundane the place looks and yet hey, what's that? A complete Elsinore ::)
You might see me cruising Lamar now and then, testing out whatever I'm working on and showing it off to Tony, who's a great sport.
You two are completely crazy. The fact that you care so much about that 200 says that much. The next time you plan on going that way, maybe stop by and see what I have going on or show me what you've got.
I don't get around much, ATM, since I sold my CB550 and am building a CL350.
Cheers.
Cheers.
Redliner will do! My daughter has played open mic at Bill's Records...saw the Flaming Lips @ Gilleys, and have had a beer or two at Lee Harveys. Yes we are crazy! Spent 5 hours to find one cl pipe and muffler, we found our cb 750 air box (with velocity stacks) above Larry, Moe, and Curley, found our rearsets off the cbr600f3. I wonder what is up here! I hear guys say, "That place is crap, he won't tell us where it is! He won't let us pull it!" My wife calls his place a mess...my son calls it heaven. Tony knows where everything is in that place...but it is way more fun to find it! Tony's Elsinore, his Suzuki two stoke in the rack in back, His little Kawi...heaven.
Oh, did he tell you that the red GS1100 is his? I may have to twist his arm and lemme take it out. Suh-weet as!
Sometimes you get lucky. I needed a new upper triple for a CB450. They had no 450k's or 500t's laying around, but what are the odds? There's an upper triple already pulled and just sitting on one of the shelves in the far end!
The parts selection is always changing and you never really know what you'll find, but you must be persistent. By now I have a pretty good idea where each bike is and in what condition ;D
teazer said:
That TZADS1 anti-draft was designed for Daytona and is worth looking at. I have two on the shelf that need various degrees of repair.
Teazer,
Will the TZADS1 fit over the rear shocks on the 175/200 cleanly or will it need to be modified?
We would be there tomorrow morning if this school stuff didn't get in the way...cheers Redliner and give a big yeeee hawwwww yell for me when you ride the GS
^ Uh sure, except that it's hard to say anything with an 80-120mph wind going up your nose and between your teeth ::)
Our cb200 five years ago at 45 seconds
http://youtu.be/-CQ6xTHXuBc
Did we do this correctly? We dropped a birthday candle into our cylinder and then fired lucky up and blew it out our tail pipe.
We did get a measurent on both the exhaust and intake valve to piston clearance...we tried tying a string to the center of a candle and seeing if we could fish it out after getting a measurement perpendicular to the spark plug hole...that didn't work so well..
Thanks Kop that was fun!
4.81mm does that sound right for a stock motor?
Sounds like you have plenty of room to play. Minimum clearance for exhaust valve to piston is .040" and intake to piston is .020". I know folks who run it even closer (.020" and .015"), but .040" and .020" are where I aim to be.
Texasstar said:
Teazer,
Just. :-)
I don't have a CB200 frame here but I just put an anti Draft seat off a TZ onto a CB160 and it clears the shocks nicely. It is somewhat wider than the frame at the front of the seat and obviously it sits back where a race seat should be and that leaves a long gap to the tank, but those are just details.
teazer said:
Just. :-)
hopefully..one day that long gap is going to be filled with an aluminum tank that our buddy Junior Burrell is going to teach Zeke how to build...form will follow function...it may be smaller than our existing tank...Did you know there is no 175 streamliner BUB record? Now that is a big gaping hole that someone should fill some day. Can't be more than .50 over on the engine...
Looks like we will be getting that TZ'er push from our tail section...just the way it has been from the beginning ;)
The stock cb 200 valve lift on the intake is...drum roll please....
.222" lift on the right cam and .218" lift on the the left.
1970 honda tolerances are still better than some of GM's
LUL, inches ::)
Anyway, it looks like you're measuring the rocker. Wouldn't that give you valve lift? Unless those rockers are 1:1...
Curious.
Redliner said:
LUL, inches ::)
Curious.
Looks like he's measuring from the top of the retainer, to me. But that measurement value would also include the lash adjustment.
But anyway... that isn't much lift at all. :-\
So he is basically measuring the valve?
I can't comment on the lift. Inches to me are as made-up as "heaps", "a helluva-lot" or "a tad". :P
Yeah... valve lift, not cam lobe height. But inches are easy... 25.4mm = 1". About .040" = 1mm.
Thanks for making me do math :P
5mm?? I think those jobby chinese engines like the 50cc GY6 have lift like that!
Are you certain you know how to use a dial-gauge? I'm just commenting from the sidelines, not being rude ;D
Sorry guys I meant valve lift. Take a look at the megacycle cams for the 160, 175, and 200. These are competition cams.
Redliner this is the first time we used a dial indicator. Well actually it was the 5th time to get these readings. We measured the retainer in the same spot on both valves...set the guage up perpendicular to the retainer and as close to parrallel to the valve. We are learning so no worries mate :)
The 200 has .270" valve lift for which is only 6.8mm
The 175 has .246" valve lift
There is only one other bike in their catalog that has less lift. The cb250 which has .217
Our valve lash is .002"
