Texasstar
Can't is a four letter dirty word
I want my son to listen to what the bike needs within the contraints of working with what you have. For example we did the math on the intake needing to be 12.5 inches long but on the dyno it was .6 HP gain with the cb750 velocity stack on the carb with stock intake length. We ran lean with the velocity stack intake long and rich with the velocity stack just on the carbs and then the kicker with an increase in HP. Apparently Lucky is telling us she needs something else to go faster.
Yesterday on the dyno for some reason one of the velocity stacks kept falling off at the extension. I put it on 4 different times and finally at the end of the runs pulled the extensions off and put the stacks on the carbs. Serendipity? Or was lucky telling us something. A .6 bump in HP is a lot for this little engine.
How important is dyno time? Look at the difference between our very first run and now. The first run was doing the status quo: remove airbox, add filters, jet up. 12.4 whp
Our last run was 16.5 because Teazer told us to listen to what our bike needed on the dyno (and Lucky kicking off her velocity stack extensions.
