Tex,
Stock CB200 has CAM height of 3.73mm ex and 3.93 In. That's on used cams measured in the shop out of an engine. CB175 are the same, but I have not done a valve lift curve for either stock cam or a new OEM cam.
Megacycle 122-00 measures up at around 4.27mm at the cam and around 6.3-6.4mm at the valve. Don't worry about what cams a CB72 uses or where that sounds like a lot or a little. Where it's important is in choosing a cam to match the flow that your motor achieves. FYI the -00 cam is the best overall cam for those motors that we tested on track and on the dyno.
