Father Son 75 CB200T Rise From the Ruins
teazer said:
I suspect that you may have fallen for the classic British understatement. When I say that our motors are basically stock I mean we don't have custom cranks - well only one does, or custom pistons - oops all three have. Or trick valve gear. Well it's not radically modified but everything has been touched in some way inside from big bore oil pumps to shorter barrels and squish band heads and so on. Let's just say that it's more of a euphemism than a truism. Our motors are just old fashioned hot rod techniques with the aid of some modern technology to save time and money.
To change rocker ratios implies that the pivot is moved to allow one arm to become relatively longer and the other side to become relatively shorter. We used to do that with Triumph twins by fitting offset rocker pivots. That way the pushrod end effectively moved closer to the pivot and increased the ratio and lift. Some of us learned those tricks back in the early seventies when those sort of parts were readily available.
On an OHC motor it's not clear to me how you would do that. It would need the rocker shafts to be moved and new rocker arms. That sounds like an interesting approach but I can buy a mild cam and be 100% sure it will fit and will make more power. There are other things I'd spend my time and cash on ahead of that project starting with that long floppy cam chain and heavy pistons with big fat rings that flutter at lowish revs.
Jut a few more things to think about and tie the synapses up. :-)
Thank you Teazer for being gracious and allowing my ignorant passion to roam. :) I know that you have 40 years of real world racing experience and you don't get to the top of a cup series by basically running "stock" machines. Not only have you been gracious to us but have to countless others, forum after forum, tirelessly answering the same questions over and over and never being condescending.
You are an excellent teacher and what you are teaching is not falling on deaf ears. Your passion to educate will beget the same passion. Zeke told me the other day he wants to road race Lucky....
teazer said:
I suspect that was the issue that Redliner was trying to remember.
Thanks mate. I was learned by my American uncles who were all semi-pro racers in any motor sport you can name. That was nearly 20 years ago. There were more types and sizes of engines than I'd like to remember. It was cold and dark and I had to hunt mice with sticks.
4th edition. I'm still on V1. I need to upgrade. Is there an app for that?
And thanks for the kind words.
Only three hours into Bell's book...
We have poor air induction
Our intake valves are not the right size for the cc's
Our intake is too big and is compromising velocity
Our pistons are big sluggish fat dogs, the wrong shape and don't promote good flame propagation.
We have no friend Mr. Squish
The ratio of our exhaust valve to intake valve is wrong...
Our hemi needs to become a semi with a bathtub...
You might consider something along these lines?
http://tboltusa.com/store/lifan-150cc-piston-kitbr-57mm-p-2408.html
I'm not sure about the height of the piston, but the wrist pin and bore will do. Gives you 1.5mm over... 209cc.
Now you get the picture... But all is not lost and remember that those are general rules rather than absolutes. Ports are too big - Unless you make them work with bigger carbs and make it turn higher revs....
Pistons are not perfect but they are what you have to work with and lower crowns mean a different combustion chamber and valve angle etc. We can't make our old bikes int 21st century designs but we can take some steps to move them a little closer.
Combustion chambers are quite deep being a semi hemi and that is where those piston domes came in. An engine is a just a series of compromises and design decisions and our task is to see what we can do within reason to change the balance of those compromises. You are getting it though.
We will work with what we have been given and we are grateful for what we have been given.
I love the story of a mini with a perfect heart combustion chamber winning the race over the big bolt on establishment! :)
Thanks for being a watchman on the wall ringing the Bell over and over....
http://youtu.be/hQoBLp2Gg3E
They make me feel sick to my stomach...it would have saved us 350 bucks. Yea and we spent more on shipping from the Netherlands to buy one of the Pistons.
If you are looking for Pistons for your Cb200 PAY ATTENTION to this post! Then go read Sonreir's tutorial on how to build a functional (and frugal) cafe racer!
Thanks Matt!
Thanks Matt!
Those pistons appear to be almost flat topped and that would give you about 6:1 compression. See if you can get your hands on a CB77 piston for comparison. It's heavy and has thick rings but........
Will do! What about the Kz550's?
Yeah... but then you can stroke it out and/or fill in some space on the head?
Don't forget about increasing displacement. Torque increases aside, an increase in displacement will also result in an increase in intake velocities and is especially useful in combating oversized intake tracts. Bumping the Honda 360 up to 378cc (from 356cc) is good for three of four ponies with almost everything else remaining stock. Increase in compression will net you between three and five percent increase in peak hp per point.
So assuming you go up to 11:1 compression (a decent number and you can probably still run pump gas), +2mm over on the bore, AND the CB200 responds as well as the 360 to these types of changes, you'd be looking at 21hp just from a piston swap and a bit of machining.
Food for thought...
KZ550 Wiseco pistons are not bad but need machining plus welding in the head. It would be cheaper and simpler to get 4 new pistons from JE.
Next Dyno run
.032" copper gasket
.0015 valve lash
.002 valve lash
.003 valve lash
85 jets
Wow looks promising Teazer!
Model Diameter Heartline-to-top Pen Diameter length
CB200 56.00 23.5+9 15 61.00
C77/CS77 60.00 24.5+7 15 66.00
We could even go out to 248cc :)
Found a four stroke honda piston library:
http://www.4-stroke.net/online-library-bibliotheek/honda-piston-size-chart
Critical dimension is pin to edge of the crown. If it's slightly low, you machine more off the block and if it's slightly high machine some off the piston to get the squish you are looking for. Not a drop in but worth looking at.
