Texasstar
Can't is a four letter dirty word
Thank you Teazer for being gracious and allowing my ignorant passion to roam.teazer said:I suspect that you may have fallen for the classic British understatement. When I say that our motors are basically stock I mean we don't have custom cranks - well only one does, or custom pistons - oops all three have. Or trick valve gear. Well it's not radically modified but everything has been touched in some way inside from big bore oil pumps to shorter barrels and squish band heads and so on. Let's just say that it's more of a euphemism than a truism. Our motors are just old fashioned hot rod techniques with the aid of some modern technology to save time and money.
To change rocker ratios implies that the pivot is moved to allow one arm to become relatively longer and the other side to become relatively shorter. We used to do that with Triumph twins by fitting offset rocker pivots. That way the pushrod end effectively moved closer to the pivot and increased the ratio and lift. Some of us learned those tricks back in the early seventies when those sort of parts were readily available.
On an OHC motor it's not clear to me how you would do that. It would need the rocker shafts to be moved and new rocker arms. That sounds like an interesting approach but I can buy a mild cam and be 100% sure it will fit and will make more power. There are other things I'd spend my time and cash on ahead of that project starting with that long floppy cam chain and heavy pistons with big fat rings that flutter at lowish revs.
Jut a few more things to think about and tie the synapses up.![]()
You are an excellent teacher and what you are teaching is not falling on deaf ears. Your passion to educate will beget the same passion. Zeke told me the other day he wants to road race Lucky....
