Re: "Patina" The 1973 CB175 Cafe Racer
yep
cafe mike said:I included your statement. And I agree
yep
xb33bsa said:cool you CAN get an even smooth idle and THEN synch the slides
it is not neccesary to synch first
however you must pull the air filters to synch so it just makes sense to do it first
carry on
cafe mike said:Your done with that part. You went to seat and went 1-1/2 turns out right?
Balance using a synchronizer .. Or exhaust pressure... I have never done the exhaust one.1sttimer said:I'm going to pull the air filters to bottom out the slides and then move the screw back in until I see it move then stop like Mike mentioned.
I honestly don't know how to do a sync. Is it just manually adjusting the threaded nipple on the top of the carb so the slides pull evenly?
cafe mike said:Balance using a synchronizer
cafe mike said:I keep forgetting to not only explain what to do, but why. Reminds me of that exercise in school when you have to explain how to make a peanut butter and jelly sandwich. When the teacher used my instructions to make one.... Mine said take piece of bread....
Yup...... she tore of a piece..... Damn it that's not what I meant I said....
On that note I amagine when I tell you to back out that screw. You take it all the way out...
I will try harder oh thinking one
Yes 1 1/4 or 1 1/2 is fine. That adjust the amount of air mixes with the fuel. Lean/rich setting... Minor...major adjustments are made with jets and needle.1sttimer said:I did but didn't have any reason for doing so. I'll keep that one at 1.5 out or bottom it out?
I hate people who do things without asking why.1sttimer said:Hey man, I'm not afraid to ask stupid questions.
I have to start somewhere. What I've found is that if I ask the stupid questions I'm more likely to get an answer than if I just pretend I know how to do things.
You got it. Are you working on the bike now???1sttimer said:So it makes sense that the revs took off if the idle screw was almost all the way in...hopefully backing that out (lowering the slide) will get me in the ballpark.
cafe mike said:You got it. Are you working on the bike now???
Look at some you tube videos of bench synchronizing... And synchronizing1sttimer said:No I'm not. Just asking questions.
i have seen some wrong ones on youtubecafe mike said:Look at some you tube videos of bench synchronizing... And synchronizing
I agree with that sync. Method. It's so bad, it's funny.xb33bsa said:that synchronizing procedure in the manual does not do shit :of course they rise and fall together they both are hooked to the throttle
we are talking about getting them synched for airflow it must be done as i layed out
the only other way to do it would be on a flow bech
or to adjust the idle screws first for the excact same slide opening using say a drillbit on each side
