We had a hiccup with our valve guide and new seat. Since we are going to single springs we had to modify the valve guide to accept the new seat. We had to remove the flare off the valve guide. The new retainer will sit on the the seat where the inner spring was before.
Had to do it the hard way...
The good news is the steering damper clears...the bad new is you can't use the rocker arm dowells from the 175 or you will be blowing oil out the left cover...yep there is a reason it was solid.
Rocker arms look nice.
I used a sanding roll at first, then switched to a flappy wheel on my dremel. The flappy wheel worked really well at smoothing out the surface. Then I switched to a scotch brite type abrasive to really get in the corners and polish it up...
They really shed the oil nicely.
Shotpeening puts the surface layer of the rocker / con rod / whatever the Eff you're doing into compression.
If there is a crack propagation zone in the part, the surface compression has a tendency to close up the crack initiation -ie, the part won't fail due to crack propagation. Its all a relative thing, though; if you have huge notches in your part with essentially no radius at the crack root, its not a question of if, but rather, when, the failure will occur.
Maybe its just me, but 220 grit as a final sand might be a bit coarse if you're not shotpeening.
There used to be a guy in my area that would shotpeen conrods for 18 bucks a shot, chump change if you ever had a rod chainsaw its way through your crankcase... but don't know if he's in business anymore.
If you can find someone who does shotpeening at a reasonable price, go for it.
In my case, I'll never see anywhere north of 10 grand by a longshot for my streetbike motor, but for you guys...
It's all good fun until someone throws a rod...
Pat
We have primordial ooze...
A. I covered an oil journal with a gasket on the tach side.
B. The cam housings are turning into aluminum dust.
C. I don't have fricken clue.
We fired her up and she sounded mean. Should we have that much more compression with a .2mm deck difference and a 57mm opening for our copper gasket instead of 57.75? It is tough to turn the crank after installing the head. She ran hot in less than a minute so we shut her down. We tightened the cam housing on the tach side twice and it still oozed...
We annealed our copper head gasket, installed hondabond ht around the oil ring. Two coat of K &W Copper coat.
Our original gasket was 1mm and our new gasket is .81mm
Metallic sheen in drained oil. Pulled the engine. Significant oil in both exhaust ports. Are we blowing exhaust up the valve stem since we cut the guide? The oil is black at th base of the guide and valve seal.
Sonreir said:
I must have missed that... you cut down the guides in the exhaust?
oh yea we saw it done on a drag bike head...
What are the stem seals like? The shorter guides make zero difference to oil coming down the guide. How loose did he ream the guides? Sounds like they may be too loose now. On a 200 head there are oil dams to keep the cams in a pool of oil and maybe the head is not draining properly from the exhaust guide area.
Check the cam and the end caps. Something is binding and it's possible that one or more of the rocker pins are not going in far enough and are keeping the end caps out too far.
BTW there is more metal to come out of that port either side of the guide boss if you need to.
I know that's a "car" thing, but I remember reading that it's maybe not such a great idea on a bike... maybe someone else can chime in... kop, teazer, adc, pj?
It's OK but remember that a shorter guide provides less support and will tend to wear out faster. I often shorten guides a little and taper the protrusions. Drag bike motors usually have a a flat port roof with no boss and no guide getting in the way. DOHC motors can stand shorter guides than SOHC with rocker arms because they have almost no side thrust from the rocker movement.
That was fun until we hit Texas tea. She is very loud...a low Growllll! I suspect you are right on the rocker pins.
It took us 5 hours to install one of the new single springs, modified the valve guide to accept the new spring seat washer and now the spring is sitting on the raised part of the guide where the middle spring use to sit. This compressed the spring about 1mm from where the outside spring was...I am wondering if the seat pressure may be to high. The good news is we had no leak on the head gasket. We are going to pull the head and take it to Wells to have them check the seat pressure and if we reamed to much. Gonna call Zach Jones @ R/D later to confirm.
We achieved coil bind! Our valve guide has a step so out seat washer was .20" high our installed height was .995 instead of 1.18 so we need to get new guides without the step. Told David it took us 5 hours to install the keepers...he did it in under 10 seconds.
Our coil bind is .83 and our cam lift is .243. Edit...the cam chain tensioner was right...
We pulled the motor and installed the vintage advantage race springs until we get some guides turned down from another head. The copper gasket was sealed tight with the copper coat and hondabond ht. Is there an easy way to remove it from the jug? We used some heat but it was still kinda a pain.
We cleaned and oiled all the journals and the engine turns with no bind. The ears didn't seem any worse for the addition stress put on them but we will measure another pair tonight to compare. We need to clean the oil filter and check the lower case for shavings tonight.
David taught us how to measure the installed spring height and Zeke says we need all of David's machines in our shed...lol. You can see the problem with the guide and how it lowered our installed spring height by .25". We may go to something like the kibblewhite guides.
