Shotpeening puts the surface layer of the rocker / con rod / whatever the Eff you're doing into compression.
If there is a crack propagation zone in the part, the surface compression has a tendency to close up the crack initiation -ie, the part won't fail due to crack propagation. Its all a relative thing, though; if you have huge notches in your part with essentially no radius at the crack root, its not a question of if, but rather, when, the failure will occur.
Maybe its just me, but 220 grit as a final sand might be a bit coarse if you're not shotpeening.
There used to be a guy in my area that would shotpeen conrods for 18 bucks a shot, chump change if you ever had a rod chainsaw its way through your crankcase... but don't know if he's in business anymore.
If you can find someone who does shotpeening at a reasonable price, go for it.
In my case, I'll never see anywhere north of 10 grand by a longshot for my streetbike motor, but for you guys...
It's all good fun until someone throws a rod...
Pat
