Zoöid Third Times a Charm CB175
We bolted the hub to a drill press and rotor broached the holes. You can see the dings we need to remove that were there previously.
Next we used a Harbor Freight High Speed mini saw to remove most of the material then it took us and hour to get the hub centered correctly on the mill. https://vimeo.com/132013427
Re: Third Times a Charm CB175
Zeke, that is awesome and way neater than any I have done. Nice work.
Pat, You will end up in trouble for child abuse keeping him working so late ....................... ;-)
Teazer time flies when you are having fun!
Well you gotta love the Italians and they love their curves. Here is what the steering stem measures for the 32mm cerianis.
The cb175 All Balls Racing Steering Stem roller bearings offered a slight challenge. The bottoms bearing is a 27mm ID and the top is a 25mm ID. Soooo we measured and the bottom bearing ID was 26.85" ish. So our phone a friend suggested that we roll a feeler gage for a shim to get an idea for making a sleeve.
I swear these parts arriving in the mail are a test or the Italians drank too much wine while machining.
So we put our all balls in the freezer and will install the chases after we
heat up our stem. (That is how the instructions should read)
Now back to the work and lacing hubs. Zeke hand filed finished sanding and polished the hubs before lacing with Buchanan's stainless spokes.
Picked up some Ospho to take care of any rust in the cracks changes iron oxide to iron phosphate. You can watch it change.
We received some Metzlers in the mail.
Before and after using Ospho
Kopism... Aluminum foil and Ospho on chrome
